[Armbian build PR] - OLIMEX Teres A64: Official support
My effort to implement an official armbian support for OLIMEX Teres A64.
How to help
Testing of the image
To capture any bugs i need testers if you want to help then: 1. Install the provided image on a class 10 A1 or higher SDCard and use it to boot the system using command # dd if=/path/to/file/img of=/dev/SDCARD_HERE conv=sync status=progress && sync * Armbian_23.02.0-trunk_Teres-a64_bullseye_current_5.15.89_minimal.img * Armbian_23.02.0-trunk_Teres-a64_bullseye_current_5.15.89_minimal.img.sha * Armbian_23.02.0-trunk_Teres-a64_bullseye_current_5.15.89_minimal.img.txt
  1. DO NOT update/upgrade the system! (apt update or apt upgrade or apt dist-upgrade) * We need reproducible results and updates will only introduce variables to the testing
  2. Pick a desktop environment for testing:
    • GNOME (tested by @Kreyren)
    • XFCE4 (wanted)
    • KDE (wanted)
    • others?
  3. Report any bugs
Help solving issues
No Audio
The current image has no audio which is currently being investigated, if you have any relevant info then let me know
GNOME
Laggy af
The animations needs to be disabled for it to be usable or the gnome build optimized
Unable to login after wrong password
When i put wrong password in the gdm it will get stuck in authentification error blinking for some reason
How to contribute
a. Clone the repository
  • $ git clone --branch=armbian-next https://github.com/armbian/build armbian-build-next
b. Build the image
  • $ ./combile.sh docker-shell
c. Put the image on your OLIMEX Teres A64 system
  • # dd if=./output/images/armbian..img of=/dev/SDCARD_HERE conv=sync status=progress
Description
Please include a summary of the change and which issue is fixed. Please also include relevant motivation and context. List any dependencies that are required for this change.
Jira reference number [AR-9999]
How Has This Been Tested?
  • [ ] Test A
  • [ ] Test B
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
Superseeds: https://github.com/armbian/build/pull/4749
View the full article
