[CNX-Software] - GL.iNet Beryl AX review with OpenWrt – WiFi 6 performance, repeater, NAS, and 4G hotspot modes
Power bank GL.iNet GL-MT3000 Beryl AX router
In the first part of the review of GL.iNet GL-MT3000 “Beryl AX” pocket-size WiFi 6 OpenWrt router we had a look at the specifications, the package content, and the hardware design with a teardown of the little. I’ve now had more time to play with the router focusing the review on WiFi 6 performance, and some of its functions such as repeater, NAS, and 4G hotspot. The router also supports VPN client and server modes, the Tor network, and Adguard Home, but I’ll invite readers to check out the GL.iNet Brume 2 security gateway review since I went through all these, and the hardware is very similar minus wireless connectivity. Initial setup of the Beryl AX router If you connect an Ethernet cable to the router you can switch to step two. If you only rely on WiFi for the setup that works too as the Beryl AX router will [...]
The post GL.iNet Beryl AX review with OpenWrt – WiFi 6 performance, repeater, NAS, and 4G hotspot modes appeared first on CNX Software - Embedded Systems News.
View the full article
