[Armbian build PR] - rockchip64 rk3328 disable dmc
Description
RK3328 dmc driver was added a few kernels ago, it is broken with 6.1 causing kernel panic and failure to boot. Remove driver, disable boards that still depend on it but can't be tested.
Patches need rebased for
nanopi r2 (all) rk3328-roc-pc nanopi neo3 orangepi R1
How Has This Been Tested?
  • [X] Build passes
  • [X] Renegade boots successfully
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
  • [X] Any dependent changes have been merged and published in downstream modules
View the full article
