[Armbian build PR] - sunxi64: fix uwe5622 compile on current 5.15 kernel
Description
Hotfix to remove a hunk from a patch that prevented compilation of uwe5622 driver on sunxi64 family for current kernel 5.15. The hunk was just "cosmetical" because it removed a compilation warning about unused variables. There seems to be some #define and #ifdef difference on sunxi64 that causes the compilation error.
Also the application of bluetooth-fix patch has been removed from drivers_network.sh since the patch has been removed in the past.
How Has This Been Tested?
  • [x] Compiled current 5.15 kernel debs for OrangePi 3 LTS (sunxi64)
  • [x] Compiled current 5.15 kernel debs for OrangePi 4 LTS (rockchip64)
  • [x] Compiled edge 6.1 kernel debs for OrangePi4 LTS (rockchip64)
There was not field testing for this change, I really expect the driver to work the same as before.
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
