[Armbian build PR] - rockchip64: fix rk3328 dmc driver
Description
Hotfix for rk3328 dram memory controller driver has some issues and causes crashes on board on which is activated (see https://github.com/armbian/build/pull/4767) on edge 6.1 kernel. This pull request fixes the issue, plus removes some cruft and warnings from the existing code.
How Has This Been Tested?
  • [x] Compile kernel deb packages successfully
  • [x] Install on a rk3318 system
  • [ ] Install on rk3328 system
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
