[Armbian build PR] - variable indicating the compression ratio rootfs
This does not affect the downloaded ready-made ROOTFS, but the new compression value dramatically increased the process time (2-4 times) for user configurations. Adding a variable indicating the compression ratio will make it easy to select the desired value according to the conditions of use of the assembly system. By default, the previous value is set, for a mass build (which is executed from command scripts), it is easy to add any value of the maintainer's choice and will allow you to maintain a high build speed for custom versions that are usually executed on conventional ARM devices with low performance.
View the full article
