[Armbian build PR] - OLIMEX Teres-A64: Official Support
Description
This merge request implements an official support for OLIMEX Teres-A64 by Armbian and assigns myself as the maintainer.
Solves the following issues:
  • OS breaking after reboot that is currently present on the weekly builds
  • No audio (Solved through including needed packages and updating debian and community olimex wiki)
  • No active maintainer
  • Removes bloatware introduced from armbian-firmware
Before Merge Checklist (Reviewer)
  • [ ] Continuous Deployment
    • [ ] Add weekly build for:
      • [ ] minimal stable debian CLI
        • e.g. BOARD=olimex-teres-a64 BRANCH=current RELEASE=bookworm BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no
      • [ ] Debian testing (bookworm) full GNOME desktop
        • e.g. BOARD=olimex-teres-a64 BRANCH=current RELEASE=bookworm BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no DESKTOP_ENVIRONMENT=gnome
      • [ ] Debian stable (bookworm) full XFCE4 desktop
        • e.g. BOARD=olimex-teres-a64 BRANCH=current RELEASE=bullseye BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no DESKTOP_ENVIRONMENT=xfce4
  • [ ] Website (https://www.armbian.com/olimex-teres-a64)
  • GNOME requires a bookworm release as the older GNOME version is basically unusable due to insufficient management of system resources by upstream
How Has This Been Tested?
  • [X] Was tested on the hardware with at least 28 hours of active use during 4 days including testing GNOME and XFCE builds.
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [X] I have commented my code, particularly in hard-to-understand areas
  • [X] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
  • [X] Any dependent changes have been merged and published in downstream modules
GIMP project file for the header: armbian-teres-mr.xcf.zip
View the full article
