FatihEke Posted February 4, 2023 Posted February 4, 2023 Hello, I have orange pi zero 2 but it doesn't work with armbian versions after kernel version 4.9.318, I tried many versions. When I check it through the serial port, it stays on "trying to boot from MMC1 armbian" and the led on it is constantly red. Also, if I upgrade the kernel with apt-get upgrade in version 4.9.318, the card does not boot afterward and gets a "No ethernet found" error. Versions I tried : Armbian_22.11.3_Orangepizero2_jammy_legacy_4.9.318.img [Worked but no wifi connection] Armbian_22.02.2_Orangepizero2_bullseye_legacy_4.9.255.img [Works good] Armbian_22.08.7_Orangepizero2_jammy_edge_5.19.16.img [Not working !!] Armbian_22.11.1_Orangepizero2_jammy_edge_6.0.10_minimal.img [Not working !!] Armbian_23.02.0-trunk.0141_Orangepizero2_jammy_edge_6.1.2.img [Not working !!] Armbian_23.02.0-trunk.0191_Orangepizero2_jammy_edge_6.1.6_minimal.img [Not working !!] Armbian_23.02.0-trunk.0236_Orangepizero2_jammy_edge_6.1.9_minimal.img [Not working !!] Armbian_23.02.0-trunk_Orangepizero2_lunar_edge_6.1.8.img [Not working !!] Armbian_23.02.0-trunk_Orangepizero2_lunar_edge_6.1.8_minimal.img [Not working !!] I tried to build it myself and the result still does not work the same. Armbian_23.02.0-trunk_Orangepizero2_jammy_current_5.15.90.img [I have built but not working] 0 Quote
randomus3r Posted February 22, 2023 Posted February 22, 2023 Same problem, it does not boot any more after kernel upgrade. Here the full boot-log: [275]HELLO! BOOT0 is starting May 13 2020 14:10:04! [280]BOOT0 commit : 593cf83 [283]set pll start [286]periph0 has been enabled [289]set pll end [291]unknow PMU [292]PMU: AXP806 [300]vaild para:1 select dram para0 [303]board init ok [305]DRAM BOOT DRIVE INFO: V0.52 [308]the chip id is 0x5000 [311]chip id check OK [313]DRAM_VCC set to 1500 mv [317]read_calibration error [321]read_calibration error [325]read_calibration error [329]read_calibration error [333]read_calibration error [337]read_calibration error [341]read_calibration error [345]read_calibration error [349]read_calibration error [352]read_calibration error [355]retraining final error [360][AUTO DEBUG]32bit,1 ranks training success! [367]DRAM CLK =720 MHZ [369]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [376]Actual DRAM SIZE =512 M [379]DRAM SIZE =512 MBytes, para1 = 30ea, para2 = 2000000, dram_tpr13 = 6041 [392]DRAM simple test OK. [394]rtc standby flag is 0x0, super standby flag is 0x0 [400]dram size =512 [402]*****dram handle ok**** [405]card no is 0 [407]sdcard 0 line count 4 [410][mmc]: mmc driver ver 2019-12-19 10:41 [414][mmc]: sdc0 spd mode error, 2 [417][mmc]: set f_max to 50M, set f_max_ddr to 25M [422][mmc]: mmc 0 bias 0 [430][mmc]: Wrong media type 0x0 [433][mmc]: ***Try SD card 0*** [443][mmc]: HSSDR52/SDR25 4 bit [446][mmc]: 50000000 Hz [448][mmc]: 7487 MB [450][mmc]: ***SD/MMC 0 init OK!!!*** [549]Loading boot-pkg Succeed(index=0). [553]Entry_name = u-boot [562]Entry_name = monitor [565]Entry_name = dtbo [568]Entry_name = dtb [572]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):9fecd83 NOTICE: BL3-1: Built : 17:08:29, 2020-05-28 NOTICE: BL3-1 commit: 8 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05-armbian (Jan 10 2023 - 07:48:03 +0000) Xunlong Software [00.647]CPU: Allwinner H616 [00.650]Model: Orange Pi Zero 2 I2C: ready [00.655]DRAM: 512 MiB Relocation Offset is: 15ec7000 [00.695]secure enable bit: 0 [00.697]PMU: AXP806 [00.702]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.884]sunxi overlay merged okqv [00.888]drv_disp_init [00.917]__clk_enable: clk is null. tv_init()950 fetch tv0 err. [00.922]drv_disp_init finish [00.925]gic: sec monitor mode [00.930]flash init start [00.932]workmode = 0,storage type = 1 [00.936]MMC: 0 [00.937][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.943][mmc]: get sdc_type fail and use default host:tm1. [00.954][mmc]: Using default timing para [00.957][mmc]: SUNXI SDMMC Controller Version:0x40200 [00.975][mmc]: card_caps:0x3000000a [00.978][mmc]: host_caps:0x3000003f [00.982]sunxi flash init ok [00.985]Loading Environment from FAT... [00.989][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [00.995][mmc]: get sdc_type fail and use default host:tm1. [01.006][mmc]: Using default timing para [01.009][mmc]: SUNXI SDMMC Controller Version:0x40200 ** Bad device mmc 1 ** Failed (-5) [01.020]usb burn from boot delay time 0 weak:otg_phy_config [01.034]usb prepare ok [01.293]usb sof ok [01.295]usb probe ok [01.297]usb setup ok set address 0x5 set address 0x5 ok [04.303]do_burn_from_boot usb : have no handshake [04.307]boot_gui_init:start 190 bytes read in 12 ms (14.6 KiB/s) Set HDMI disp_mode to 1080p60 190 bytes read in 13 ms (13.7 KiB/s) Set fb0_width to 1280 Set fb0_height to 720 [04.617]boot_gui_init:finish [04.619]bmp_name=/boot/boot.bmp 230454 bytes read in 37 ms (5.9 MiB/s) [04.670]update dts Net: [04.674]No ethernet found. Hit any key to stop autoboot: 1 0 no mmc device at slot 1 [05.700][mmc]: card_caps:0x3000000a [05.703][mmc]: host_caps:0x3000003f switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3259 bytes read in 15 ms (211.9 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 190 bytes read in 12 ms (14.6 KiB/s) 262144 bytes read in 42 ms (6 MiB/s) ** File not found /boot/dtb/allwinner/overlay/-fixup.scr ** 7227589 bytes read in 620 ms (11.1 MiB/s) ** File not found /boot/Image ** Unknown command 'booti' - try 'help' SCRIPT FAILED: continuing... No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found. armbian# 0 Quote
cabanak Posted March 3, 2023 Posted March 3, 2023 Same problem after upgrade (apt-get upgrade) from from 22.11.1 to 23.02.02 can't boot Last runing is: Armbian_22.11.1_Orangepizero2_bullseye_edge_6.0.10 with kernel Linux 5.19.16-sunxi64 Attached log file opi2.log 0 Quote
Darius82 Posted March 7, 2023 Posted March 7, 2023 I was worried as the led does not even blink. I tried installing an old image and it worked but as soon as I upgraded it to the last version it did not boot anymore. Also, it kicked me out of the session. How can I help providing logs? 0 Quote
