RSS Bot Posted February 8, 2023 Posted February 8, 2023 The ComfilePi CPi-C070WR4C is a 7-inch industrial Panel PC powered by a Raspberry Pi CM4 module with GPIO, RS-232, RS-485, and I2C interfaces as well as the ability to add two more RS232 interfaces and several 12V-24V DC inputs and outputs through an I/O board connected to the GPIO port of the panel PC. The new panel PC is an update to the ComfilePi Industrial Touch Panel PC introduced with a Raspberry Pi CM3 module in 2017. Besides upgrading to a more powerful Raspberry Pi Compute Module 4, COMFILE also makes use of an RS-485 port that utilizes a full UART interface that does not exhibit the limitations of the mini-UART interface, and also added the CP-IO13-4C I/O board for even more expansion capabilities. ComfilePi CPi-C070WR4C specifications: SoM – Raspberry Pi Compute Module 4 with SoC – Broadcom BCM2711 quad-core Arm Cortex-A72 processor @ 1.5GHz with VideoCore Vi GPU supporting [...] The post Raspberry Pi CM4 based 7-inch industrial Panel PC takes IO board with RS232, 12V-24V inputs and outputs appeared first on CNX Software - Embedded Systems News. View the full article
