Can't get Banana Pi M1 work with sata anymore (22.11)
Hey,
I recently decided to give the 22.11 a try on my M1, but I can't get my sata SSD to be the system root and boot again. 18.04 it worked for me with the exact same setup.
I used this:
https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-nvme-usb
went with
armbian-install
only option for me was boot from SD and system on sata. But after the preparation of the ssd, the reboot always runs into emergency mode with not really good hints how to solve, or what even the issue is.
Any tips or hints are welcomed.
https://paste.armbian.com/awewolefiy
actual armbianmonitor,
I guess it is running now as intended. I had a little tweek to do in the /etc/fstab when I run into the emergency mode after armbian-install and reboot.
bananapi:/boot:# cat /etc/fstab
# <file system>					<mount point>	<type>	<options>						<dump>	<pass>
tmpfs						/tmp		tmpfs	defaults,nosuid						0
716d0a51-462c-4919-8ab8-c24bf9d3e0f6	/media/mmcboot	ext4    defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
/media/mmcboot/boot  				/boot		none	bind							0       0
UUID=dfd5ab2a-b792-4fde-836d-c4ae7ff9986f	/		ext4	defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
changed to:
UUID=716d0a51-462c-4919-8ab8-c24bf9d3e0f6	/media/mmcboot	ext4    defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
 The "UUID=" was missing for the entry of the SD-card. Is this any hint to a problem in the scripts?
