[Armbian build PR] - build(deps): bump actions/upload-artifact from 3.0.0 to 3.1.2
Bumps actions/upload-artifact from 3.0.0 to 3.1.2.
Release notes
Sourced from actions/upload-artifact's releases.
v3.1.2
  • Update all @actions/* NPM packages to their latest versions- #374
  • Update all dev dependencies to their most recent versions - #375
v3.1.1
  • Update actions/core package to latest version to remove set-output deprecation warning #351
v3.1.0
What's Changed
Commits
  • 0b7f8ab ci(github): update action/download-artifact from v1 to v3 (#312)
  • 013d2b8 Create devcontainer for codespaces + update all dev dependencies (#375)
  • 055b8b3 Bump Actions NPM dependencies (#374)
  • 7a5d483 ci(github): update action/checkout from v2 to v3 (#315)
  • e0057a5 README: Bump actions/checkout to v3 (#352)
  • 7fe6c13 Update to latest actions/publish-action (#363)
  • 83fd05a Bump actions-core to v1.10.0 (#356)
  • 3cea537 Merge pull request #327 from actions/robherley/artifact-1.1.0
  • 849aa77 nvm use 12 & npm run release
  • 4d39869 recompile with correct ncc version
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
