This will be my first time using Armbian and OrangePi, sorry if theres stupid questions.
I want to write a C++ application that uses LVGL to display information on a USB screen and have a few questions.
1) Will I be able to this screen in this setup. It uses the frame buffer (/dev/fb0). There are instructions for RaspberryPi, where its just plugged in and the frame buffer is available to use.
2) If I just use the latest Armbian Ubuntu version for this board what is the newest version of C++ I can use? (C++11/14/17 etc)
3) Is there a tool chain available to be able to cross compile my application (specifically from MacOS) then put the binary on the OrangePi? Or will I have to use something like docker and build for ARM?
Thanks!
