dondon Posted February 22, 2023 Posted February 22, 2023 (edited) Hello, running Armbian_22.11.2_Odroidm1_bullseye_edge_6.1.0.img.xz + updates. I saw in other post (/topic/17418-cameras-with-rock-pi-4-c/😞 Quote $ sudo armbian-config Then select System > Hardware > rpi-cam-imx219 But I do not see any Hardware menu in System. I had a look to armbian-config and saw that there is a lot of device-specific code and probably odroidm1 is not supported yet. Also I searched for some DTB that may work, but none is shipped with the current kernel: Quote $ apt-file search imx219.dtb | cut -d : -f 1 | sort | uniq | grep linux-image-edge-rk3568-odroid is empty. Should I add explicit support like in this patch: https://github.com/armbian/build/pull/1482/files? Or there are more modern way to add cold-pluggable hardware? Thanks in advance for your suggestions! Edited February 22, 2023 by dondon fix url 0 Quote
