WiFi isn't working on the current legacy image: Armbian_22.11.3_Orangepizero2_jammy_legacy_4.9.318.img
[FAILED] Failed to start Access poi…server for Wi-Fi and Ethernet.
See 'systemctl status hostapd.service' for details.
[  OK  ] Finished OpenVPN service.
openvpn.service
[  OK  ] Started /etc/rc.local Compatibility.
rc-local.service
rpc-statd-notify.service
[  OK  ] Started Notify NFS peers of a restart.
[  OK  ] Finished Permit User Sessions.
systemd-user-sessions.service
[  OK  ] Started Bluetooth service.
bluetooth.service
[  OK  ] Reached target Bluetooth Support.
         Starting Hold until boot process finishes up...
         Starting Terminate Plymouth Boot Screen...
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
         Starting Hostname Service...
[  OK  ] Finished resolvconf-pull-resolved.service.
[  OK  ] Finished Hold until boot process finishes up.
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Finished Terminate Plymouth Boot Screen.
[   19.330374] proc: unrecognized mount option "hidepid=invisible" or missing value
Armbian 22.11.3 Jammy ttyS0
orangepizero2 login: [   22.434473] WCN_ERR: dumpmem_rx_callback open  error no.-21 retry:1
[   22.608383] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   22.726784] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   22.845212] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   22.963555] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   23.081861] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   23.200187] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   23.318572] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   23.437000] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   23.555333] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   23.673674] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   23.792089] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   23.910506] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.028921] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.147344] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.265778] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.384217] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.502618] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.621046] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.739480] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.857837] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   24.976168] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   25.094571] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   25.212879] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   25.331223] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   25.449659] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   25.568189] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   25.686517] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   25.804861] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   25.923205] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   26.041563] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   26.159978] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
[   26.166416] sunxi-mmc sdc1: retry:set phase failed or over retry times
[   26.173888] sunxi-mmc sdc1: retry:give up
[   26.178527] sdiohal err:dt read fail ret:-110, system_addr=0x4024f000
[   26.187652] WCN_ERR: mdbg_dump_data dump memory error:-110
[   26.193952] WCN_ERR: read HCI_ARM_WR_RD_MODE reg error:-1
[   26.200105] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.206191] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.212273] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.218347] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.224430] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.230510] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.236538] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.242632] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.248709] WCN_ERR: mdbg_dump_data dump memory error:-1
[   26.254770] WCN_ERR: mdbg_dump_data dump memory error:-1
[   35.679877] WCN_ERR: Not dump again!
Edited by gyrex
  • gyrex changed the title to WiFi not working on OrangePi Zero 2
I also tried the Bullseye legacy kernel image Armbian_22.11.3_Orangepizero2_bullseye_legacy_4.9.318.img and after running my first apt update/upgrade I get this:
3259 bytes read in 15 ms (211.9 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
190 bytes read in 11 ms (16.6 KiB/s)
262144 bytes read in 42 ms (6 MiB/s)
** File not found /boot/dtb/allwinner/overlay/-fixup.scr **
7227822 bytes read in 625 ms (11 MiB/s)
** File not found /boot/Image **
Unknown command 'booti' - try 'help'
SCRIPT FAILED: continuing...
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
