[Armbian build PR] - Draft: Banana Pi R2 (CSC) current and edge
Description
  • Fix legacy u-boot patch, update to use v2022.07
  • Remove unreliable onboard bt/wifi driver
  • Add current target (5.10) - works and tested on SD with minimal image
  • Add edge target (6.1) - hangs at boot
TODO
  • [ ] test eMMC install
  • [ ] test HDMI output
  • [ ] resolve 6.1 hang/oops
  • [ ] remove legacy target
Jira reference number [AR-9999]
How Has This Been Tested?
  • [x] Install legacy image on SD, boot OK
  • [x] Install current image on SD, boot OK
  • [x] network: configure DSA switch as router (wan, br0: lan0..3)
  • [x] network: mPCI wifi (ath10k) + USB wifi (rt2800usb)
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
