I am creating a script that can backup sd-cards running on the system, resizing it with desired value or via resize2fs calculated.
I learn a lot but there are a few things I don't fully understand.
When I create a backup I dd what I understand is the bootsector, ie I grab the "start" position of the partition I am backing up with fidisk  and use that value and a blocksize of 512. I then add another 10mb (in bytes) just to be sure. Usually the bootsector is 8192 big, but not always (IIRC nanopi neo3;s is WAY bigger).
dd bs=512 count=$DDBOOTSECTOR if=/dev/mmcblk0 of=$IMG_FILE conv=noerror,sync status=progress
I then truncate the file, calculated either by resize2fs minimum calculation or via an input + file usage in df (depending of what flag I start the script with) + bootsector + yadayadayda. (if someone want me to post the script I will, but the script and calculations work, although I "force" some commands)
I then loop the created img file and delete the partition on the /dev/loop0 and recreates it to cover 100%.
Then format it with mkfs.ext4 copying the name and uuid from wherever I backup from.
I mount the loop and rsync /
rsync -ahvD --exclude={/lost+found,/proc/*,/sys/*,/dev/*,/tmp,/run/*,/mnt/*,/media/*,/var/log.hdd,/var/swap,/etc/udev/rules.d/70-persistent-net.rules,/var/lib/asterisk/astdb.sqlite3-journal} --info=progress2 --stats --delete --force --partial / $tmp_dir
This seems to work, but there are probably some things that are just "accepted" not really "perfect".
So questions:
1. Should I only dd the EXACT bootsector and not add the extra 10mb? The reason I ask is because if I try to delete the partition with parted, I have to do a hack in the scrip where I simulate button presses, it warns me that "the partition cant be outside of the disk" when I try to REMOVE it. Solution, I use sfdisk to remove the partition, but it prompts me to think there is something wrong going on here. If the size I create is ABOVE the resize2fs reported minimum i don't get this warning. sfdisk was the solution in this case, but still curious on this behavior. If I try to only dd the small part, it sometimes works, sometimes doesn't so I come here asking. (I might be able to do some further research but since I have other questions, why not ask)
2. Does armbian ever update the u-boot via apt?
I do my next update with rscync by looping the file and mounting it. But that wont EVER cover the bootsector.
2b. If yes, do I solve this by again dd:ing ONLY the bootsector?
3. I have noticed that sudo apt update on armbian includes armhf even though running arm64. This makes the update process VERY long.
dpkg --print-foreign-architectures
shows armhf so i remove it with
dpkg --remove-architecture armhf
and then
find /var/lib/apt/lists/ -type f -exec rm {} -v \;
Seems to fix this but is this a bad idea? Why is the armhf even being fetched to begin with?
To my memory I have not added arhmf architecture...
Thanks in advance!
Edited by bedna
typos
