[Armbian build PR] - Fix "No space left on device" while rsync root files to image
Description
In some file systems, calling du shows an invalid amount of occupied filespace. The solution is to call du with the option --apparent-size
Cons: With this option du shows a slightly smaller size than the files can actually take up, because only the net sum of the file sizes is counted without taking into account the hit to the cluster size.
Fixes: https://github.com/armbian/build/pull/4857
Jira reference number AR-1556
How Has This Been Tested?
  • [X] Tested build with/without tmpfs on zfs.
  • [ ] Test B
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
