[CNX-Software] - RAKwireless programmable 5G & LoRaWAN small cell device runs Ubuntu on Raspberry Pi CM4
RAKwireless 5G small cell
RAKwireless “All-in-One 5G” is a programmable 64-bit Ubuntu indoor device that integrates AGW (access gateway) through a Raspberry Pi CM4 as well as 5G and 4G LTE cellular and LoRaWAN connectivity. The device is powered through its 2.5GbE PoE++ port and designed for private 5G networks for industrial automation, public safety, and transportation, and RAKwireless says you can also “start earning cryptocurrency by providing LTE cellular and LoRa coverage”, but I could not find details about monetization at this time. RAKwireless “All-in-One 5G” specifications: SoM (AGW) – Raspberry Pi CM4 system-on-module with Broadcom BCM2711 quad-core Cortex-A72 processor with 4GB RAM and 32 eMMC flash, WiFi 5 and Bluetooth 5.0 connectivity 5G/4G cellular connectivity LTE Mode- TDD Frequency Bands – Band 48 (3550 MHz to 3700 MHz); band N78 is also supported for global coverage Channel Bandwidth5/10/15/20 MHz Max TX Power – 24 dBm Receiver Sensitivity – -100 dBm Built-in 2-port [...]
The post RAKwireless programmable 5G & LoRaWAN small cell device runs Ubuntu on Raspberry Pi CM4 appeared first on CNX Software - Embedded Systems News.
View the full article
