[CNX-Software] - Microchip unveils Single Pair Ethernet (SPE) 10BASE-T1S and 100BASE-T1 Ethernet devices
Microchip Single Pair Ethernet
Microchip has introduced a range of industrial-grade Single Pair Ethernet (SPE) devices for IIoT and industrial Operational Technology (OT) networks for low-speed Ethernet edge devices and a simplified cabling infrastructure for latency-sensitive applications. Microchip LAN8650/LAN8651 10BASE-T1S single pair Ethernet Controllers The LAN8650 and LAN8651 10BASE-T1S MAC-PHY Ethernet controllers come with an SPI for integration into basic microcontrollers rather than higher-end MCUs with a MAC. They can be used to connect sensors, actuators, and other devices over a simple twisted-pair cable. Microchip LAN8650/LAN8651 specifications: High-performance 10BASE‑T1S single-pair Ethernet PHY Compliant with IEEE Std. 802.3cg-2019 (10BASE-T1S) 10 Mbps over a single balanced pair of conductors Half-duplex point-to-point link segments up to at least 15m Half-duplex multidrop mixing segments up to at least 25m with up to at least 8 PHYs Integrated Media Access Controller (MAC) Host interface – SPI Supports time-sensitive networking (TSN) by timestamping frame ingress and egress EtherGREEN Energy Efficiency [...]
The post Microchip unveils Single Pair Ethernet (SPE) 10BASE-T1S and 100BASE-T1 Ethernet devices appeared first on CNX Software - Embedded Systems News.
View the full article
