[Armbian build PR] - Add support for BPI-CM4 with BPI-CM4IO
Description
This introduces support for the BPI-CM4 module following the specifications of the RPI-CM4 module, using the BPI-CM4IO baseboard, but should support any CM4 compatible baseboards.
https://wiki.banana-pi.org/Banana_Pi_BPI-CM4
The Linux DT changes has been submitted (https://lore.kernel.org/all/20230303-topic-amlogic-upstream-bpi-cm4-v2-0-2ecfde76fc4d@linaro.org/) and merged (https://git.kernel.org/amlogic/c/0262f2736978b1763363224698f47112a148dab0) upstream, the U-Boot changes are still in review (https://lore.kernel.org/all/20230307-u-boot-cm4-v1-0-43f5a393cd37@linaro.org/)
How Has This Been Tested?
Full testing must be done before switching this PR out of draft.
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
