SuperMaximus Posted March 18, 2023 Posted March 18, 2023 How can I make sure my /boot is protected against power failure making eMMC of Tinkerboard corrupted? Is it possible to mount read-only /boot while leaving the rest of FS writeable? I know about Overlay root FS, it's OK, but I need to protect only boot. Please help to mount it properly. Thanks! 0 Quote
CryBaby Posted March 18, 2023 Posted March 18, 2023 Edit /etc/fstab line for boot partition and add ro option: /dev/mmcblk0p1 /boot vfat defaults,noatime,noauto,x-systemd.automount,ro 0 0 0 Quote
SuperMaximus Posted March 18, 2023 Author Posted March 18, 2023 @CryBaby Thanks! Is this action enough to prevent corruption of bootloader during unexpected power outage? 0 Quote
CryBaby Posted March 19, 2023 Posted March 19, 2023 Yes, assuming /boot is a separate partition. I do this with my Raspberry Pis as I have very unreliable power. I also set them to check filesystems on boot by adding fsck.mode=force to the kernel command line. On OSMC that is in /boot/cmdline.txt, on armbian it might be in /boot/uBoot.env, on a grub machine in /etc/default/grub (then run update-grub). 0 Quote
SuperMaximus Posted March 22, 2023 Author Posted March 22, 2023 @CryBaby Could you please advise how to make a separate partition on Armbian for "/boot"? I was tinkering with attempts to make /boot read-only via u-boot CLI, but had no luck. I mean not only making a partition as such, but also telling Armbian that /boot is on another mmcblk. I am using Tinkerboards EMMC. Thanks! 0 Quote
CryBaby Posted March 27, 2023 Posted March 27, 2023 If /boot is not already a separate partition I would think there is not much advantage in making it one. The main problem is machines that need a FAT formatted boot partition, as FAT is so fragile. I don't know if your Tinkerboard is one. If /boot is on an ext4 partition then fscking at boot is going to be adequate protection in most cases. If you really want to mess with your partitions I think you will have to understand the boot process of your Tinkerboard in some detail. Does boot have to be the first partition? What filesystems are acceptable? What files need to be in it and what should they contain? 0 Quote
