[Armbian build PR] - allwinner-boot-splash.patch: Fix sunxi uboot redefined warnings on "CONFIG_VIDEO_*"
Description
Current U-Boot compile on SUNXI 32-bit boards comes up with a couple of CONFIG_ redefined warnings.
Root cause is allwinner-boot-splash.patch. If CONFIG_VIDEO or CONFIG_DM_VIDEO is defined, then this patch is defining a couple of dependent configs - regardless if those are defined already.
Solution
Wrap those defines with an appropriate if !defined pattern.
How Has This Been Tested?
  • [x] Test 1: Compile for a SUNXI 32-bit board - e.g.: /compile.sh u-boot BOARD=bananapipro BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,7z SYNC_CLOCK=no CREATE_PATCHES=no
  • [x] Test 2: Compile for a SUNXI 64-bit board does not create any warning.
Checklist:
View the full article
