[Armbian build PR] - Move "Repeat Build Options" logs to start-end.sh to appear consistently on any build
Description
IMO the "Repeat Build Options" log should consistently appear for any build option. So I did update scripts as follows (copy of commit comment):
  • cli-build.sh, start-end.sh:
    • move function produce_repeat_args_array() to start-end.sh
    • add $WHAT as first arg to produce_repeat_args_array() if $WHAT is not empty
    • move early display log of "Repeat Build Options" to function main_default_start_build()
    • move last log of "Repeat Build Options" to function main_default_end_build()
    • add last log of "Repeat Build Options" to LOG_SECTION="repeat_build_options"
How Has This Been Tested?
  • [x] A: Run full build (no single artifact on commandline): image
  • [x] B: Run single artifact build with uboot on commandline:
    • the early log: image
    • the final log: image
Checklist:
View the full article
