bask Posted March 27, 2023 Posted March 27, 2023 Hello, I'm using a Banana Pi P2-Zero based on H3 and I want to get Ethernet running. To no avail so far... When building the image, I use this parameters: BOARD=bananapim2zero BRANCH=current RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=no I use the customize-image.sh script, but I don't change anything related to the drivers (or so I think). There are no patches, overlays or anything like that. I saw this topic but this solution doesn't help: I also tried something like this but it didn't help either: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&emac>; __overlay__ { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&emac_rgmii_pins &emac_clk_out_pins>; phy-mode = "rgmii"; }; }; }; Using ifconfig -a I only see lo and wlan. The LEDs at the ethernet socket are on constantly. I am sure that the hardware is working properly because ethernet works on the ready image from the Internet. Unfortunately, I can't use this image Does anyone know how to enable this ethernet? 0 Quote
bask Posted March 28, 2023 Author Posted March 28, 2023 I found a solution. I used dts from here: https://stackoverflow.com/questions/73557042/how-to-enable-eth0-on-banana-pi-zero-m2/73557043 and I used the armbian-add-overlay command instead of using dtc 0 Quote
