[CNX-Software] - Convert your 3D printer into a metal cutting machine with an Electrical Discharge Machining kit (Crowdfunding)
Powercore EDM 3D printer kit
Rack Robotics’ Powercore is an Electrical Discharge Machining (EDM) kit that converts your existing 3D printer (or CNC router) into a machine capable of cutting high-precision and detailed metal parts. We’ve already seen 2-in-1 3D printers and laser engravers such as the Creality Ender 3 S1 Pro, but while this type of machine can usually cut plywood or engrave stainless steel, the laser is not powerful enough to cut through aluminum. The Powercore EDM kit changes that by enabling the cutting of aluminum parts up to 4mm thick, although aluminum sheets that are 1mm or thinner are recommended. But before we get into Powercore details, what is Electrical Discharge Machining exactly? Engineers Edge explains: Electrical Discharge Machining, EDM is one of the most accurate manufacturing processes available for creating complex or simple shapes and geometries within parts and assemblies. EDM works by eroding material in the path of electrical discharges [...]
The post Convert your 3D printer into a metal cutting machine with an Electrical Discharge Machining kit (Crowdfunding) appeared first on CNX Software - Embedded Systems News.
View the full article
