[CNX-Software] - HIGOLE PC STICK (J4125+WiFi 6) review – Part 1: Specs, unboxing, teardown, and first boot
HIGOLE PC STICK Review
HIGOLE PC STICK is a mini PC that looks like a large flash drive, is smaller than a regular mini PC, and is easier to carry around. You can connect it directly to a monitor or TV with an HDMI input, and use it like any computer right away. In part 1 of the HIGOLE PC STICK review, we will go through the specifications, unbox the design, check its hardware design with a teardown, and go through the first boot. HIGOLE PC STICK specifications The HIGOLE PC STICK is powered by an Intel Celeron J4125 quad-core Gemini Lake Refresh processor with 8GB RAM, 128GB flash, and microSD card slot for storage expansion. The mini PC comes with a Gigabit Ethernet port, WiFi 6 and Bluetooth 5.2 connectivity, and supports two independent displays through the HDMI 2.0 port and USB Type-C port. The device also includes two USB 3.0 ports, one [...]
The post HIGOLE PC STICK (J4125+WiFi 6) review – Part 1: Specs, unboxing, teardown, and first boot appeared first on CNX Software - Embedded Systems News.
View the full article
