Anneress Posted April 12, 2023 Share Posted April 12, 2023 Hello, I tried to use the power button on my Rock 4 C+ running Armbian 23.02.2 Bullseye with Linux 5.15.93-rockchip64. It is able to power off. But I can't boot up the controller. When I use the debian based radxa image the button works like expected. I found this at the rk3399-rock-4c-plus.dts of the radxa kernel. &rockchip_suspend { status = "okay"; rockchip,sleep-debug-en = <1>; rockchip,sleep-mode-config = < (0 | RKPM_SLP_ARMPD | RKPM_SLP_PERILPPD | RKPM_SLP_DDR_RET | RKPM_SLP_PLLPD | RKPM_SLP_CENTER_PD ) >; rockchip,wakeup-config = < (0 | RKPM_GPIO_WKUP_EN | RKPM_PWM_WKUP_EN | RKPM_USB_WKUP_EN | RKPM_USB_LINESTATE_WKUP_EN ) >; rockchip,pwm-regulator-config = < (0 | PWM2_REGULATOR_EN ) >; rockchip,power-ctrl = <&gpio1 17 GPIO_ACTIVE_HIGH>, <&gpio1 14 GPIO_ACTIVE_HIGH>, <&gpio0 3 GPIO_ACTIVE_HIGH>; }; I would test the overlay with current armbian build, but I doesn't know where to place it. Maybe someone can help me here? 0 Quote Link to comment Share on other sites More sharing options...
