[Armbian build PR] - extensions: `rkdevflash`: simplify usage of `rkdeveloptool` (on Linux)
extensions: rkdevflash: simplify usage of rkdeveloptool (on Linux)
Usage: ./compile BOARD=xxx [...] EXT=rkdevflash
Will build rkdeveloptool for you, and after image is built, enters a loop waiting for device. Then either uploads rkbin loader if in Maskrom mode, or straight flashes the image if in Loader mode. Finally it reboots the device after flashing.
View the full article
