Hi.
Please help me   to understand  how hardware  encoding works   in nanopi  with H3 chipset.
I have    newest version of armbianos:
uname -a
Linux nanopineo 5.15.93-sunxi #23.02.2 SMP Fri Feb 17 23:49:46 UTC 2023 armv7l armv7l armv7l GNU/Linux
cedrus and  related modules is  loaded    by kernel
lsmod
Module                  Size  Used by
rfkill                 20480  1
sunrpc                327680  1
snd_usb_audio         200704  0
sun4i_gpadc_iio        16384  0
lz4hc                  16384  0
snd_hwdep              16384  1 snd_usb_audio
industrialio           57344  1 sun4i_gpadc_iio
snd_usbmidi_lib        28672  1 snd_usb_audio
lz4                    16384  0
uvcvideo               77824  0
snd_rawmidi            28672  1 snd_usbmidi_lib
sunxi_cedrus           40960  0
videobuf2_vmalloc      20480  1 uvcvideo
snd_seq_device         16384  1 snd_rawmidi
v4l2_mem2mem           20480  1 sunxi_cedrus
sun8i_thermal          16384  0
videobuf2_dma_contig    20480  1 sunxi_cedrus
videobuf2_memops       20480  2 videobuf2_dma_contig,videobuf2_vmalloc
videobuf2_v4l2         20480  3 uvcvideo,sunxi_cedrus,v4l2_mem2mem
videobuf2_common       40960  7 uvcvideo,sunxi_cedrus,videobuf2_dma_contig,videobuf2_vmalloc,videobuf2_memops,v4l2_mem2mem,videobuf2_v4l2
evdev                  20480  1
uio_pdrv_genirq        20480  0
uio                    16384  1 uio_pdrv_genirq
cpufreq_dt             20480  0
zram                   24576  3
sch_fq_codel           20480  2
usb_f_acm              20480  1
u_serial               24576  3 usb_f_acm
g_serial               16384  0
libcomposite           45056  2 g_serial,usb_f_acm
ramoops                24576  0
reed_solomon           16384  1 ramoops
pstore_blk             16384  0
pstore_zone            24576  1 pstore_blk
ip_tables              24576  0
x_tables               28672  1 ip_tables
autofs4                36864  2
sunxi                  16384  0
phy_generic            20480  2 sunxi
gpio_keys              20480  0
There are  following    hardware acceleration methods   and encoders
 ffmpeg  -hide_banner  -hwaccels
Hardware acceleration methods:
vdpau
vaapi
drm
/usr/bin/ffmpeg  -hide_banner  -encoders  |  grep  264
 V..... libx264              libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (codec h264)
 V..... libx264rgb           libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 RGB (codec h264)
 V..... h264_omx             OpenMAX IL H.264 video encoder (codec h264)
 V..... h264_v4l2m2m         V4L2 mem2mem H.264 encoder wrapper (codec h264)
 V....D h264_vaapi           H.264/AVC (VAAPI) (codec h264)
Please   explain me what i am  doing wrong  here :
ffmpeg  -y  -hide_banner -loglevel debug  -t 00:00:20   -f v4l2  -video_size 1280x720   -i /dev/video1  -c:v h264_vaapi      1234.mp4
Splitting the commandline.
Reading option '-y' ... matched as option 'y' (overwrite output files) with argument '1'.
Reading option '-hide_banner' ... matched as option 'hide_banner' (do not show program banner) with argument '1'.
Reading option '-loglevel' ... matched as option 'loglevel' (set logging level) with argument 'debug'.
Reading option '-t' ... matched as option 't' (record or transcode "duration" seconds of audio/video) with argument '00:00:20'.
Reading option '-f' ... matched as option 'f' (force format) with argument 'v4l2'.
Reading option '-video_size' ... matched as AVOption 'video_size' with argument '1280x720'.
Reading option '-i' ... matched as input url with argument '/dev/video1'.
Reading option '-c:v' ... matched as option 'c' (codec name) with argument 'h264_vaapi'.
Reading option '1234.mp4' ... matched as output url.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option y (overwrite output files) with argument 1.
Applying option hide_banner (do not show program banner) with argument 1.
Applying option loglevel (set logging level) with argument debug.
Successfully parsed a group of options.
Parsing a group of options: input url /dev/video1.
Applying option t (record or transcode "duration" seconds of audio/video) with argument 00:00:20.
Applying option f (force format) with argument v4l2.
Opening an input file: /dev/video1.
[video4linux2,v4l2 @ 0x14a6100] fd:3 capabilities:84a00001
[video4linux2,v4l2 @ 0x14a6100] Current input_channel: 0, input_name: Camera 1, input_std: 0
[video4linux2,v4l2 @ 0x14a6100] The V4L2 driver changed the pixel format from 0x32315559 to 0x47504A4D
[video4linux2,v4l2 @ 0x14a6100] Trying to set codec:rawvideo pix_fmt:yuv420p
[video4linux2,v4l2 @ 0x14a6100] The V4L2 driver changed the pixel format from 0x32315659 to 0x47504A4D
[video4linux2,v4l2 @ 0x14a6100] Trying to set codec:rawvideo pix_fmt:yuv422p
[video4linux2,v4l2 @ 0x14a6100] The V4L2 driver changed the pixel format from 0x50323234 to 0x47504A4D
[video4linux2,v4l2 @ 0x14a6100] Trying to set codec:rawvideo pix_fmt:yuyv422
[video4linux2,v4l2 @ 0x14a6100] All info found
Input #0, video4linux2,v4l2, from '/dev/video1':
  Duration: N/A, start: 14668.719509, bitrate: 147456 kb/s
  Stream #0:0, 1, 1/1000000: Video: rawvideo, 1 reference frame (YUY2 / 0x32595559), yuyv422, 1280x720, 0/1, 147456 kb/s, 10 fps, 10 tbr, 1000k tbn, 1000k tbc
Successfully opened the file.
Parsing a group of options: output url 1234.mp4.
Applying option c:v (codec name) with argument h264_vaapi.
Opening an output file: 1234.mp4.
[file @ 0x14acb30] Setting default whitelist 'file,crypto,data'
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_vaapi))
Press [q] to stop, [?] for help
cur_dts is invalid st:0 (0) [init:0 i_done:0 finish:0] (this is harmless if it occurs once at the start per stream)
[rawvideo @ 0x14a8d60] PACKET SIZE: 1843200, STRIDE: 2560
detected 4 logical cores
[graph 0 input from stream 0:0 @ 0x14af470] Setting 'video_size' to value '1280x720'
[graph 0 input from stream 0:0 @ 0x14af470] Setting 'pix_fmt' to value '1'
[graph 0 input from stream 0:0 @ 0x14af470] Setting 'time_base' to value '1/1000000'
[graph 0 input from stream 0:0 @ 0x14af470] Setting 'pixel_aspect' to value '0/1'
[graph 0 input from stream 0:0 @ 0x14af470] Setting 'frame_rate' to value '10/1'
[graph 0 input from stream 0:0 @ 0x14af470] w:1280 h:720 pixfmt:yuyv422 tb:1/1000000 fr:10/1 sar:0/1
[format @ 0x14af6c0] Setting 'pix_fmts' to value 'vaapi_vld'
[auto_scaler_0 @ 0x14b0420] Setting 'flags' to value 'bicubic'
[auto_scaler_0 @ 0x14b0420] w:iw h:ih flags:'bicubic' interl:0
[format @ 0x14af6c0] auto-inserting filter 'auto_scaler_0' between the filter 'Parsed_null_0' and the filter 'format'
Impossible to convert between the formats supported by the filter 'Parsed_null_0' and the filter 'auto_scaler_0'
Error reinitializing filters!
Failed to inject frame into filter network: Function not implemented
Error while processing the decoded data for stream #0:0
[AVIOContext @ 0x14ad6c0] Statistics: 0 seeks, 0 writeouts
[video4linux2,v4l2 @ 0x14a6100] Some buffers are still owned by the caller on close.
ioctl(VIDIOC_QBUF): Bad file descriptor
Conversion failed!
and here:
ffmpeg  -y  -hide_banner -loglevel debug  -f v4l2  -video_size 1280x720  -i /dev/video1 -vf 'format=yuyv422'       -t 00:00:20  -c:v h264_v4l2m2m      1234.mp4
Reading option '-vf' ... matched as option 'vf' (set video filters) with argument 'format=yuyv422'.
Reading option '-c:v' ... matched as option 'c' (codec name) with argument 'h264_v4l2m2m'.
[video4linux2,v4l2 @ 0x1e950f0] fd:3 capabilities:84a00001
[video4linux2,v4l2 @ 0x1e950f0] Current input_channel: 0, input_name: Camera 1, input_std: 0
[video4linux2,v4l2 @ 0x1e950f0] The V4L2 driver changed the pixel format from 0x32315559 to 0x47504A4D
[video4linux2,v4l2 @ 0x1e950f0] Trying to set codec:rawvideo pix_fmt:yuv420p
[video4linux2,v4l2 @ 0x1e950f0] The V4L2 driver changed the pixel format from 0x32315659 to 0x47504A4D
[video4linux2,v4l2 @ 0x1e950f0] Trying to set codec:rawvideo pix_fmt:yuv422p
[video4linux2,v4l2 @ 0x1e950f0] The V4L2 driver changed the pixel format from 0x50323234 to 0x47504A4D
[video4linux2,v4l2 @ 0x1e950f0] Trying to set codec:rawvideo pix_fmt:yuyv422
[video4linux2,v4l2 @ 0x1e950f0] All info found
  Duration: N/A, start: 15145.086581, bitrate: 147456 kb/s
Applying option vf (set video filters) with argument format=yuyv422.
Applying option c:v (codec name) with argument h264_v4l2m2m.
[file @ 0x1e9a390] Setting default whitelist 'file,crypto,data'
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_v4l2m2m))
[rawvideo @ 0x1e97d40] PACKET SIZE: 1843200, STRIDE: 2560
[Parsed_format_0 @ 0x1e9c100] Setting 'pix_fmts' to value 'yuyv422'
[graph 0 input from stream 0:0 @ 0x1e9c4d0] Setting 'video_size' to value '1280x720'
[graph 0 input from stream 0:0 @ 0x1e9c4d0] Setting 'pix_fmt' to value '1'
[graph 0 input from stream 0:0 @ 0x1e9c4d0] Setting 'time_base' to value '1/1000000'
[graph 0 input from stream 0:0 @ 0x1e9c4d0] Setting 'pixel_aspect' to value '0/1'
[graph 0 input from stream 0:0 @ 0x1e9c4d0] Setting 'frame_rate' to value '10/1'
[graph 0 input from stream 0:0 @ 0x1e9c4d0] w:1280 h:720 pixfmt:yuyv422 tb:1/1000000 fr:10/1 sar:0/1
[AVFilterGraph @ 0x1e9b870] query_formats: 4 queried, 3 merged, 0 already done, 0 delayed
[h264_v4l2m2m @ 0x1e99840] probing device /dev/video2
[h264_v4l2m2m @ 0x1e99840] driver 'uvcvideo' on card 'A4tech FHD 1080P PC Camera: A4t' in splane mode
[h264_v4l2m2m @ 0x1e99840] v4l2 output format not supported
[h264_v4l2m2m @ 0x1e99840] probing device /dev/video1
[h264_v4l2m2m @ 0x1e99840] probing device /dev/video0
[h264_v4l2m2m @ 0x1e99840] driver 'cedrus' on card 'cedrus' in splane mode
[h264_v4l2m2m @ 0x1e99840] v4l2 capture format not supported
[h264_v4l2m2m @ 0x1e99840] Could not find a valid device
Thanks a lot.
Same situation here.
Documenting.
kernel module sunxi-cedrus seems to work, i see it responsible for:
/dev/v4l    <=
/dev/media0 <=
/dev/video0 <=
I guess the correct ffmpeg codec might be h264_v4l2m2m, but when i use it, i always get:
[h264_v4l2m2m @ 0x26de9c0] Could not find a valid device
[h264_v4l2m2m @ 0x26de9c0] can't configure encoder
A command example might be:
ffmpeg -i input.mp4 -an -vcodec h264_v4l2m2m -b:v 2M -pix_fmt nv21 out.mp4
So  i guess we are missing an environment variable or a library, or permissions?
Any help will be appreciated.
Thanks.
------------------------extension---------------
using:
ffmpeg -loglevel debug -i /home/garfius/input.mp4 -vf scale=1920:1080 -vcodec h264_v4l2m2m -y -an -pix_fmt nv12 -b:v 2M   test.mp4
Get:
[Parsed_scale_0 @ 0x21ed1a0] w:1024 h:768 fmt:yuvj420p sar:1/1 -> w:1920 h:1080 fmt:nv12 sar:3/4 flags:0x4
[h264_v4l2m2m @ 0x21ba660] probing device /dev/video0
[h264_v4l2m2m @ 0x21ba660] driver 'cedrus' on card 'cedrus' in splane mode
[h264_v4l2m2m @ 0x21ba660] v4l2 capture format not supported
[h264_v4l2m2m @ 0x21ba660] Could not find a valid device
[h264_v4l2m2m @ 0x21ba660] can't configure encoder
Edited by garfius
