RSS Bot Posted April 17, 2023 Posted April 17, 2023 small batch of lib fixes (mid+/April'23) Fixing the last batch. Some stupid mistakes. revert: run kernel make through pipetty for moar colors (breaks make menuconfig) - thanks @EvilOlaf artifacts: add git SHA1 sanity checking memoize-cached: add flock locking to run_memoized() to avoid error when run in parallel lib: shellfmt & fix gen-library to match artifact: rootfs: fix artifact_rootfs_config_dump() with added rootfs pkgs (should work now, I promise) View the full article
