RSS Bot Posted April 20, 2023 Posted April 20, 2023 Description I change both edge and current. vdd-log supply is pwm-supply, not vin-supply. Fixes vdd-log supply ending up the dummy regulator. [ 1.783479] pwm-regulator vdd-log: Looking up pwm-supply from device tree [ 1.783505] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed [ 1.783556] vdd_log: supplied by regulator-dummy Per https://lore.kernel.org/all/20211227234529.1970281-2-heiko@sntech.de/ there will be no functional change as the supplying regulator is an always-on fixed-regulator. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [ ] Test A [ ] Test B Checklist: [ ] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
