[Armbian build PR] - rk3328: add patch to enabled pcm5102 DAC on I2S1 bus
Description
RK3328 devices often have I2S1 bus available on expansion pins. This PR introduces an overlay to enable the I2S1 bus for Rock Pi E to enable external PCM5102 DAC; I2S1 is shared for internal audio codec and external GPIO pins, so the overlay also disables the internal audio codec.
This has been tested and proved to work on Rock Pi E, should work on other boards with similar board wiring setup, but can be also used as a base for other board/DAC combos in the future.
Jira reference number AR-1670
How Has This Been Tested?
  • [x] Kernel compiles successfully with patch applied
  • [x] Manually installed the dtbo on a living community image for rockpi-e running edge kernel
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
