RSS Bot Posted April 25, 2023 Posted April 25, 2023 Lumination Labs’ Sonatino is an ESP32-S3 board designed for audio applications that follows the Raspberry Pi Zero dimensions so that it can be used with some of the cases designed for the Raspberry Pi Zero. The wireless audio board features Cirrus Logic WM8524 audio DAC and WM8782 audio DAC capable of 24-bit 192kHz stereo output and mono input respectively, a speaker amplifier and two pins for speaker connection, a 3.5mm audio jack, as well as a microSD card slot for the storage of audio or other data. Sonatino specifications: Wireless Module – ESP32-S3-WROOM-1 with SoC – ESP32-S3 dual-core LX7 microprocessor @ up to 240 MHz with Vector extension for machine learning Memory – 2MB PSRAM Storage – 16MB flash Connectivity – WiFi 4 and Bluetooth 5 LE/Mesh Storage – MicroSD card slot (SPI) Audio 3.5mm audio jack supporting input and output (TRRS, CTIA standard) Speaker connection: onboard pins, optional [...] The post Sonatino – A Raspberry Pi Zero-sized ESP32-S3 audio board appeared first on CNX Software - Embedded Systems News. View the full article
