[CNX-Software] - Mixtile Core 3588E Rockchip RK3588 system-on-module works with NVIDIA Jetson TX2 NX carrier boards
Rockchip RK3588 SoM NVIDIA Jetson TX2 NX alternative
Mixtile Core 3588E is a system-on-module powered by a Rockchip RK3588 SoC and equipped with the 260-pin SO-DIMM connector found in the NVIDIA Jetson TX2 NX (and Jetson Nano, Xavier NX, Orin Nano modules). We’ve seen several companies make Raspberry Pi CM4 alternatives such as Radxa CM3 or Pine64 SoQuartz, and Mixtile even has its own Core 3568M SoM that can be used as a drop-in replacement for the Raspberry Pi CM4. But I had not seen companies try to make system-on-modules based on NVIDIA Jetson’s 260-pin SO-DIMM edge connector, and that’s exactly what the Mixtile Core 3588E has to offer. Mixtile Core 3588E specifications: SoC – Rockchip RK3588 CPU – Octa-core processor with 4x Arm Cortex-A76 cores @ up to 2.4 GHz, 4x Arm Cortex-A55 cores GPU – Arm Mali-G610 MP4 GPU with support for OpenGL ES3.2, OpenCL 2.2, Vulkan1.1 AI accelerator – 6 TOPS NPU with support for [...]
The post Mixtile Core 3588E Rockchip RK3588 system-on-module works with NVIDIA Jetson TX2 NX carrier boards appeared first on CNX Software - Embedded Systems News.
View the full article
