[CNX-Software] - Review of TwoTrees TTC 450 CNC router machine with 80W and 500W spindles
TwoTrees TTC450 CNC router machine review
TwoTrees TTC 450 is a CNC router machine for precision cutting with a working area of 460x460x80 mm. The machine can handle 2D and 3D, 3-axis X, Y, Z movement, features a 32-bit microcontroller,  a touchscreen control display, and supports WiFi network connection. The TTC 450 can also read files on an SD card for offline operation, and workpieces can be made of a variety of materials such as wood, acrylic, Plastwood, carbon fiber sheet, aluminum, metal, and various engineering plastic materials. TTC 450 CNC router specifications Work Area – 450 x 450 X 80 mm Body Material – Metal frame & Aluminium 4080U Profile Drive System – Translation screw drive with double Y-axis system Mainboard – DLC32 V2.1 (ESP32-based as found in TwoTrees TS2 laser engraver) Stepper Driver – A4988 1.3A Stepper Motors – 17HS8401S, NEMA23 20mN.m Spindle – 74W, 8000RPM Max Speed – 800mm/Min Running Accuracy – +/-0.1mm [...]
The post Review of TwoTrees TTC 450 CNC router machine with 80W and 500W spindles appeared first on CNX Software - Embedded Systems News.
View the full article
