[Armbian build PR] - disable spi flash support on radxa e25
Description
#5114 There is no spi flash on radxa-e25, just disable the uboot spi support should be okay. For other rk35xx boards with spi flash, both BOOT_SUPPORT_SPI and BOOT_SPI_RKSPI_LOADER should be declared just like rock-5b: https://github.com/armbian/build/blob/main/config/boards/rock-5b.conf
How Has This Been Tested?
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
