RSS Bot Posted May 4, 2023 Posted May 4, 2023 Description I copied patches from rockchip64-6.1 to rockchip64-6.3 and made the following changes: deleted patch/kernel/archive/rockchip64-6.3/board-rock3a-cec.patch since upstream merged deleted patch/kernel/archive/rockchip64-6.3/board-rock3a-gmac1.patch since upstream merged deleted patch/kernel/archive/rockchip64-6.3/board-rock3a-pcie.patch since upstream merged deleted patch/kernel/archive/rockchip64-6.3/general-enhance-backport-es8328-driver.patch because this patch is for station p1 and upstream device tree don't need it modified patch/kernel/archive/rockchip64-6.3/board-pbp-add-dp-alt-mode.patch to match upstream changes. modified patch/kernel/archive/rockchip64-6.3/board-rock3a-emmc-sfc.patch to match upstream changes. modified patch/kernel/archive/rockchip64-6.3/board-rock3a-usb3.patch to match upstream changes. modified patch/kernel/archive/rockchip64-6.3/board-rockpis-0018-ASoC-codecs-Add-RK3308-internal-codec-driver.patch to match upstream changes. modified patch/kernel/archive/rockchip64-6.3/drv-spi-spidev-remove-warnings.patch to match upstream changes. modified patch/kernel/archive/rockchip64-6.3/general-rockchip-overlays.patch to match upstream changes. modified patch/kernel/archive/rockchip64-6.3/regulator-add-fan53200-driver.patch to match upstream changes. I also fixed uwe5622 building on 6.3 kernel. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Kernel built sucessfully and run well on rock3a. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
