[Armbian build PR] - fix rock4 boards uboot spi image creating
Description
https://github.com/armbian/build/commit/5dee9ee935703a559992478fa8045b464af72b50#commitcomment-111988535 Rockpi4 is using BL31 blobs to build uboot, so it should get configed with BOOT_SCENARIO="tpl-spl-blob". If BOOT_SCENARIO is not declared it will be only-blobs by default, which will not build tpl/u-boot-tpl.bin and spl/u-boot-spl.bin needed by spi image creating. So it's better to declare BOOT_SCENARIO="tpl-spl-blob" just like rockpro64. I don't have rock4 board so someone has to confirm this fix.
How Has This Been Tested?
  • [x] uboot build successfully for rockpi 4a/4b/4c/4bplus/4cplus
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
