[CNX-Software] - SONOFF SNZB-02D review – A Zigbee temperature & humidity sensor with a 2.5-inch display
Sonoff SNZB-02D review
We’ve previously tested the SNZB-02 Zigbee temperature and humidity sensor with the SONOFF NSPanel Pro smart panel, but ITEAD has now launched the SONOFF SNZB-02D that integrated the same features plus a 2.5-inch display to visualize the data. They’ve sent us a SNZB-02 sample for review, so after listing the specifications we’ll test SONOFF’s latest Zigbee sensor with Home Assistant. SONOFF SNZB-02D specifications Display – 2.5-inch black&white display Connectivity – Zigbee 3.0 Sensors Temperature sensor with -9.9°C to 60°C range, ±0.2°C accuracy Humidity sensor with 5%—95%RH range, ±2%RH accuracy Battery – 3V CR2450 coin-cell battery good for about 2 years with a 5-second polling rate Dimensions – 62.5 x 59.5 x 18.5mm Material – PC Color: White Unboxing and first try We’ll find the sensor in the usual orange package used for Zigbee devices. The SNZB-02D sensor comes with a quick start guide and a pre-installed battery. Just pull the [...]
The post SONOFF SNZB-02D review – A Zigbee temperature & humidity sensor with a 2.5-inch display appeared first on CNX Software - Embedded Systems News.
View the full article
