RSS Bot Posted May 8, 2023 Posted May 8, 2023 squash some warnings (found during all-artifacts+all-images builds on CI) When building "all" the things, these kind of innofensive WARNs pile up. Clean them up a bit. Raises the estimate of 2000MiB to 2300MiB for CLI images. This was determined empirically. binfmts: don't raise warning if qemu-arm failed to load under aarch64 (some are native, some are emulated, all are good) reported by @igorpecovnik on Discord, during massive CI build, when armhf builds landed on arm64 builders logging: squash undue warnings rootfs/aptcache rootfs is built with BOARD= so just live with it (idea about this warn was that families might hook rootfs build process) count, instead of du, apt caches. seems some empty dirs are reported as "1Mb" by du? host-utils: more logging for when junk is found in image apt caches logging: curb some warnings into info's rootfs: bump non-desktop tmpfs_estimated_size from 2000mb to 2300mb (determined empirically, after building all images) pipeline: gha: fix IMAGES_ONLY_OUTDATED_ARTIFACTS and SKIP_IMAGES by exporting them so Python can see; tune logging View the full article
