[Armbian build PR] - use the same patch dir for u-boot from radxa
Description
There are many rk3588 boards using u-boot from radxa, and they share the same patch fix_source_so_boot_scr_works.patch. It's better to have just one patch in the repo. So I create one common patch dir legacy/u-boot-radxa-rk3588 for all boards using radxa's u-boot. Since 0001-Add-defconfig-and-dtb-of-nanopi6.patch and add-board-mekotronics-r58.patch won't harm other boards so I also move them to the common dir. If someone want board specfic patches, he can put them to patch/u-boot/legacy/u-boot-radxa-rk3588/board_${BOARD}, just like patch/u-boot/legacy/u-boot-radxa-rk3588/board_hinlink-h88k/uboot-hinlink-h88k-config.patch.
How Has This Been Tested?
  • [x] rock-5b u-boot
  • [x] hinlink-h88k u-boot
  • [x] mekotronics-r58x u-boot
  • [x] nanopi-r6s u-boot
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
