[Armbian build PR] - AR-1708 - Improve i3-wm support
Description
This PR contains update to make creation of armbian i3-wm images possible for the following distributions listed by their code names.
  • jammy
  • focal
  • bookworm
  • bullseye
Jira reference number AR-1708
How Has This Been Tested?
So far I have made sure that the images can be built and that they are bootable and functional. Testing was done on real hardware, bare metal.
  • [X] Test A - able to create the image in the first place without errors present
  • [X] Test B - check if bootable and can be used like a regular i3-wm setup
Checklist:
Not sure what to mark exactly, so leaving most of these blank for now
  • [] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [] I have commented my code, particularly in hard-to-understand areas
  • [] I have made corresponding changes to the documentation
  • [] My changes generate no new warnings
View the full article
