Power NanoPi NEO from Smartphone and interact with it
Lolo Borrego
Hello!
Brand new user here to the NanoPi Neo and even the forum.
I'm planning to use a NanoPi Neo as hardware "interactor", the main idea is to connect a NanoPi Neo to a smartphone (Android or iOS), power the board from the USB cable and work in Host Mode to interact with de smartphone with libimobiledevice or adb.
OTG does not support charging + data at the same time without a "special" OTG adapter. What I want to do is power the NanoPi by using the smartphone and even interact with it in host mode, like a regular computer will do, in simple terms, using a single cable, but getting power from it.
Is this possible using NanoPi microUSB+OTG port?
Can this be archieved in "gadget mode"? (Tutorial) I'm new to this OTG, USB dual-role thing and I can't fully understand it.
Do I need a hardware mod?
Is the only way to archieve this feature to usea an adapter with external power-in ??
Very many thanks for your help.
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
