[Armbian build PR] - Backport CM4 to kernel 6.1 LTS
Description
BPI-CM4 CM4IO dts/dtsi backport to Linux 6.1 LTS Added "current" to the KERNEL_TARGET variable
Jira reference number AR-1723
How Has This Been Tested?
  • [X] Added the relevant patch to the meson64-6.1 patch directory and adjusted the board .conf file to support both current and edge.
  • [X] Issued the following command to make sure it pulls and builds: ./compile.sh BOARD=bananapicm4io BRANCH=current kernel
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
