[Armbian build PR] - Removing not needed skel copying, fix executing bit
Description
Remove postinst manipulation as its not needed. SKEL is copied at user creation, psd goes up at first run if its there.
Also fix executing bit at armbian-firstlogin script
Jira reference number AR-1706
How Has This Been Tested?
  • [x] Image with removed get psd up and skel is also copyed
View the full article
