RSS Bot Posted May 22, 2023 Posted May 22, 2023 Description Add support for BigTreeTech CB1 (Allwinner H616) board AXP313A PMIC HDMI HDMI Audio H616 Audio Codec AC200 or AC300 (Drive automatic detection) ethernet PHY inside the H616 chip Onboard RTL8189FS WIFI Jira reference number [AR-9999] How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] HDMI: The CLI and desktop displays are both normal [x] H616 Audio Codec: LINEOUTL/R aplay -D hw:0,0 /usr/share/sounds/alsa/Noise.wav output audio is normal [x] AC200 or AC300: recognize the PHY(ac200/ac300) and connect to the network normally [x] RTL8189FS WIFI: connect to the network normally [x] HDMI Audio: The kernel driver is normal, but there is a problem with the Armbian userspace, when the gnome installed, aplay -D hw:1,0 tests that the HDMI output audio is normal. After removing gnome, aplay -D hw:1,0 has no audio output Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [ ] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
