RSS Bot Posted May 25, 2023 Posted May 25, 2023 Description Add cpu-frequency to orangepizero2, allwinner h616 6.x.y kernels Follow up Jira reference number AR-1683 How Has This Been Tested? Armbian 23.05.0-trunk Bullseye ttyS0 orangepizero2 login: alistair Password: ___ ____ _ _____ ____ / _ \| _ \(_) |__ /___ _ __ ___|___ \ | | | | |_) | | / // _ \ '__/ _ \ __) | | |_| | __/| | / /| __/ | | (_) / __/ \___/|_| |_| /____\___|_| \___/_____| Welcome to Armbian 23.05.0-trunk Bullseye with bleeding edge Linux 6.2.16-sunxi64 No end-user support: built from trunk System load: 13% Up time: 0 min Memory usage: 8% of 984M IP: 10.0.0.12 CPU temp: 42°C Usage of /: 5% of 29G [ Menu-driven system configuration (beta): sudo apt update && sudo apt install armbian-config ] alistair@orangepizero2:~$ dmesg | grep cpu* [ 0.000000] percpu: Embedded 19 pages/cpu s38760 r8192 d30872 u77824 [ 0.000000] pcpu-alloc: s38760 r8192 d30872 u77824 alloc=19*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes [ 0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.041807] cpuidle: using governor menu [ 0.062518] cryptd: max_cpu_qlen set to 1000 [ 0.700973] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) [ 0.875685] ledtrig-cpu: registered to indicate activity on CPUs [ 2.053265] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 8.995945] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 408000 KHz, changing to: 480000 KHz [x] Test A BUILD compiled and booted Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
