RSS Bot Posted May 25, 2023 Posted May 25, 2023 BPI-CM4 IO: RTW88: Realtek 8822CS SDIO Wireless Support Additional driver support: Realtek 8822BS SDIO wireless network adapter Realtek 8822BU USB wireless network adapter Realtek 8822CS SDIO wireless network adapter Realtek 8822CU USB wireless network adapter Realtek 8821CS SDIO wireless network adapter Realtek 8821CU USB wireless network adapter Jira reference number AR-1724 How Has This Been Tested? Built a new kernel with the latest changes, installed it, added required firmware and rebooted. ____ ____ _ ____ __ __ _ _ ___ ___ | __ )| _ \(_) / ___| \/ | || ||_ _/ _ \ | _ \| |_) | | | | | |\/| | || |_| | | | | | |_) | __/| | | |___| | | |__ _| | |_| | |____/|_| |_| \____|_| |_| |_||___\___/ Welcome to Armbian 23.05.0-trunk Bookworm with Linux 6.1.30-meson64 No end-user support: built from trunk System load: 2% Up time: 31 min Memory usage: 4% of 3.69G IP: 10.0.0.XXX CPU temp: 52°C Usage of /: 6% of 30G RX today: 4.9 MiB [ 0 security updates available, 19 updates total: apt upgrade ] Last check: 2023-05-25 07:50 Last login: Tue May 23 14:27:27 2023 lsmod | grep rtw rtw88_8822cs 16384 0 rtw88_8822c 462848 1 rtw88_8822cs rtw88_sdio 20480 1 rtw88_8822cs rtw88_core 159744 2 rtw88_8822c,rtw88_sdio mac80211 606208 2 rtw88_sdio,rtw88_core cfg80211 430080 2 rtw88_core,mac80211 sudo iwconfig lo no wireless extensions. end0 no wireless extensions. wlan0 IEEE 802.11 ESSID:"XXX" Mode:Managed Frequency:5.785 GHz Access Point: A2:3D:CF:FF:C5:EB Bit Rate=175.5 Mb/s Tx-Power=20 dBm Retry short limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=62/70 Signal level=-48 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:28 Missed beacon:0 Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
