Dantes Posted June 7, 2023 Share Posted June 7, 2023 (edited) I've been playing around with the 3d hardware acceleration on jammy, so I can use KODI without stuttering. And that works fine although the KODI version is a bit outdated. So I installed it doing this, under root: add-apt-repository ppa:liujianfeng1994/panfork-mesa add-apt-repository ppa:liujianfeng1994/rockchip-multimedia apt update apt dist-upgrade apt install mali-g610-firmware rockchip-multimedia-config but how do I revert: apt purge --yes mali-g610-firmware rockchip-multimedia-config apt autoremove --yes apt dist-upgrade --yes add-apt-repository --yes --remove ppa:liujianfeng1994/panfork-mesa add-apt-repository --yes --remove ppa:liujianfeng1994/rockchip-multimedia I tried this, but its not a 100%, because I'm having issues with firefox playing videos after. If anyone knows, I'm all ears Edited June 7, 2023 by Dantes 0 Quote Link to comment Share on other sites More sharing options...
Dantes Posted June 28, 2023 Author Share Posted June 28, 2023 What I did not understand was that after installing the 'hardware acceleration' it replaces ffmpeg and a bunch of libraries. All these dependencies need to be removed and that does not go as smooth as it should, but I finally found out how to do it: sudo apt purge --yes mali-g610-firmware rockchip-multimedia-config sudo apt autoremove --yes sudo apt dist-upgrade --yes sudo add-apt-repository --yes --remove ppa:liujianfeng1994/panfork-mesa sudo add-apt-repository --yes --remove ppa:liujianfeng1994/rockchip-multimedia sudo apt update --yes sudo apt purge ffmpeg libavcodec-extra sudo apt install --fix-broken sudo apt autoremove sudo apt install ffmpeg libavcodec-extra Maybe someone smarter can optimize it, but hey I can play YouTube video's again 0 Quote Link to comment Share on other sites More sharing options...
