[Armbian build PR] - `meson64` `edge`: bump 6.2 to 6.4 + reworks + use bare DT's and overlays
meson64 edge: bump 6.2 to 6.4 + reworks + use bare DT's and overlays
  • meson64 edge 6.2: rebase v6.2.16, drop Makefile patches, archeology, mbox'ing
    • drop empty doc patch add-board-bananapi-cm4-cm4io.patch
  • meson64 edge 6.2: update .config with no changes
  • meson64 edge 6.4: initial copy (as-is) of 6.2 patches
  • meson64 edge: bump from 6.2 to 6.4 (family file + symlink)
  • meson64 edge 6.4: add 0000.patching_config.yaml for meson64
  • meson64 edge 6.4: drop patches that landed upstream and backports
  • meson64 edge 6.4: rebase to 6.4-rc5; 7 are failing to apply
  • meson64 edge 6.4: drop patches for boards that landed; change BPICM4 from add to board with pyavitz's fixes
  • meson64 edge 6.4: rework board-bananapim5-sd-use-270-mmc-clock-phase-via-dt.patch
  • meson64 edge 6.4: drop ODROID-N2+'s gpio fan patches, something similar landed upstream
  • meson64 edge 6.4: simple fix for drv-spi-spidev-remove-warnings.patch
  • meson64 edge 6.4: hammer general-gpu-drm-add-new-display-resolution-2560x1440.patch
  • meson64 edge 6.4: drop general-meson-gx-mmc-fix-deferred-probing.patch -- upstreamed
  • meson64 edge 6.4: rework general-meson-mmc-3-arm64-dts-docs-Update-mmc-meson-gx-documentation-for.patch into YAML
  • meson64 edge 6.4: update .config at 6.4-rc5
    • enable a bunch of new _MESON and _AMLOGIC stuff
  • meson64 edge 6.4: drop overlay patches in favor of bare overlays in specific folder
  • meson64 edge 6.4: drop null-patched DTS files, add them bare in dt/ folder
    • convert add-board-t95z.patch to board-t95z-add-rc-remote-keymap.patch since that's all that's left
    • -spinor DTS really should be overlays, but keep them as alternate .dtbs for now
This depends and requires https://github.com/armbian/build/pull/5308
View the full article
